Re: Prima che se ne vada....
io sul mio " vecchio " 4 SE avevo aggiornato ed è sempre filato tutto liscio... anche questa della CG5 AGT l'ho aggiornato ed idem.... il rumore che diminuisce è solo perchè puoi impostare una velocità minore... è una cretinata.... le altre funzioni invece sono ottime....
Version 4 Hand Control (firmware files are named
GEM)
- 4.21 - Fixed bugs related to tandem operation (OTA orientation), Meridian Mode and land objects.
- 4.20 - Added "Custom Rate 9": the ability to set the maximum slew rate during a GoTo (requires motor control version 5.20 or higher). Fixed a problem with a runaway slow slew if a GoTo is too near the meridian flip point. No Response errors now give a "Press UNDO to continue" option. For mounts with a GPS module in use, changed the messages displayed to clarify when the GPS was still attempting a link and when it was successful. Fixed and error when syncing on stars in southern hemisphere via the RS-232 sync command (for example, from a planetarium program running on a laptop).
- 4.19 - Adjust communication protocol to assist MCupdate. Fixed an error in the GoTo RA-Dec menu item. Hand Control now reports immediately if the are communication ("No Response") difficulties at start up.
