Nuova versione di Stellarium
Troverete QUI l'ultima versione di Stellarium 0.18.1 rilasciata lo scorso 01 luglio.
Questi gli aggiornamenti:
Stellarium 0.18.1
2018-07-01 10:10:00 +0000 by alex-w
The major changes of this version:
Improvements and fixes for Hierarchical Progressive Surveys [HiPS] support
Updated code of plugins
Updated code and data
Updated GPS handling
Added rise, transit and set times for celestial objects
Added dithering support
A huge thanks to the people who helped us a lot by reporting bugs!
Full list of changes:
Added filtering for pulsars
Added option for Telrad
Added nomenclature for Charon
Added new time steps for AstroCalc/Ephemeris tool
Added support Mandarin Chinese language
Added support of hi-res screenshots (GH: #141)
Added few small improvements for Quasars plugin
Added tooltips for color buttons in Pulsars plugin
Added option to hiding invisible satellites in markers mode (GH: #145)
Added angular size for the estimated values of coma and gas tail for comet
Added support decimal degrees for size of DSO
Added improvements for proportional size textures for large DSO (GH: #159)
Added atmospheric mixing and extinction handling to Toast Survey (GH: #158)
Added Korean translation for landscape description (GH: #170)
Added shortkeys for change light pollution (GH: #171)
Added rise, transit and set times for celestial objects (GH: #169)
Added info about duration of the solar day
Added scripting function to retrieve environment variables.
Added changeability of magnitude limit for stars through keyboard shortcuts (GH: #174)
Added Korean ISL File and Update iss.cmake (GH: #185)
Added allowing storing script output to absolute path
Added equatorial radius / diameter info for Solar system bodies
Added calculation of equatorial rotation velocity for Solar system bodies (except comets)
Added 2 more lines to ArchaeoLines plugin
Fixed load the HiPS sources through proxy
Fixed creating screenshots on retina displays
Fixed behaviour Macbook’s touchpad
Fixed result of dithering color components with exactly zero tail
Fixed dithering for OpenGL ES2
Fixed enabling various lines when Telrad is enabled (GH: #109)
Fixed error in DSO catalogs filter
Fixed bug when screenshots folder can’t be changed via GUI (LP: #1764084, GH: #144)
Fixed compile with Qt5.10 (Windows/Visual Studio 2015) (GH: #139)
Fixed visibility of splash screen (GH: #142)
Fixed rendering asterisms names
Fixed editing telescope properties for Telescope Control plugin
Fixed memory leak of Bayer pattern texture in StelPainter (GH: #154)
Fixed HiPS server requests (GH: #156)
Fixed infotext brightness when planets are switched off
Fixed crash after customization of absolute/relative scales
Fixed operational status string for satellites
Fixed incorrect pair counts in constellationship.fab files (GH: #167)
Fixed color issue for formatting infostring
Fixed selection in AstroCalc/Positions tool
Fixed fullscreen toggle on Mac OS X (GH: #193)
Fixed User Agent string for HiPS
Fixed the SSO isolated trails checkbox. (GH: #199)
Fixed a rendering bug with spheric mirror distortion (LP: #1777320)
Updated behaviour of Toast: lazily creation of the grid
Updated help of Telescope Control plugin
Updated HiPS behaviour: try to use caching as much as possible
Updated user agent string for HiPS browser
Updated nomenclature list
Updated main GUI
Updated GUI of plugins
Updated Satellites plugin
Updated list of contributors
Updated catalog of pulsars
Updated behaviour of Search Tool for craters
Updated Quasars plugin
Updated format for DSO’s size
[SUG] Updated year for copyright notices
Updated Korean Star Names (GH: #173)
Updated hyperlinks for DOIs resolver (GH: #187)
Updated CMake rules for Windows/MSVC (GH: #183, #188)
Updated textures
Updated Scripting Engine: extended behaviour for includes files in scripts
Updated the code: remove some redundant calls to increase code readability. (GH: #184)
Updated the code: replaces foreach macro by C++11 range-based for. (GH: #195)
Updated the code: remove gVector, use Vec3d instead. (GH: #197)
Updated the code: C++11 auto to replace complicated hand written types. (GH: #196)
Updated the code: disable debug logging on OpenGLES mode. (GH: #201)
Updated the code: remove the null pointer check after new. (GH: #202)
Updated the code: check struct size by using static_assert. (GH: #203)
Updated the code: put dwarf galaxies and h400 tables into static array. (GH: #204)
Updated the code: call getDecYear in getDeltaTByEspenakMeeus. (GH: #205)
Updated the code: remove some new/delete pairs, just use variables on stack. (GH: #206)
Updated CMake code: enable persistent usage of C++11 standard for compiling (GH: #192)
Re: Nuova versione di Stellarium
appena scaricata ed adesso la provo subito!!
per la cronaca ho creato il mio personalissimo landscape che mi permette subito di capire quello che riesco a vedere e quello che non posso vedere dal mio balconcino di casa :sad:
tanto per farvi capire la mia situazione osservativa eccovi due istantanee
Allegato 30161
questa per il tardo pomeriggio
Allegato 30162
e questa verso mezzanotte...
:cry:
ho provato a lanciare la nuova versione e mi sono accorto che
- impostando il mio nuovo landscape ,
- salvando la configurazione,
- uscendo dal programma e
- rientrando... rimane il landscape di default (il praticello) :shock:
ho provato con altri landscape ma fa la stessa cosa... (invece con la 0.18.0 il cambio di landscape funzionava regolarmente)
ovviamente ho già inviato la segnalazione del bug nell'apposita pagina del sito... :cool:
vi aggiornerò quando avrò una risposta da parte dei bravissimi programmatori :) (di solito entro un paio di giorni!)
Pierluigi Panunzi
invece nella 0.18.0 anche a me tornava alle impostazioni di default (il praticello!).
ah sì? grazie!
boh non me n'ero mai accorto...
comunque mi sembra un bug
non vedo perché , se cambio un landscape e salvo la configurazione, lo debba reimpostare tutte le volte!:shock:
Pierluigi Panunzi
.....ho creato il mio personalissimo landscape che mi permette subito di capire quello che riesco a vedere e quello che non posso vedere dal mio balconcino di casa...
Bellissimo, come hai fatto??
non è molto facile e forse c'è qualcosa di meglio, ad esempio nel manuale di Stellarium
a grandi linee:
- con il tablet ho realizzato una foto panoramica di giorno, con il cielo di un colore abbastanza uniforme
- con paintshop pro ho eliminato il cielo rendendolo trasparente
- con l'app chiamata Dioptra ho scattato varie foto per trovare azimut ed elevazione di punti importanti del panorama
- ho ridotto l'immagine panoramica ad un'immagine da 2048x1024 pixel
- ho centrato l'immagine nel file di definizione del landscape
ognuno di questi punti richiederebbe un approfondimento... :shock:
E' stata rilasciata, da qualche giorno, la versione 19.0 di Stellarium
Stellarium v0.19.0 - Gli aggiornamenti:
5 new sky cultures
Refactoring the code: many improvements and fixes
Added many DSO textures
Many improvements for Scripting Engine
Thank you very much to community for bug reports, feature requests and contributions!
Added new type of computation for AstroCalc/Phenomena tool
Added GUI options to change constellations and asterisms font size (GH: #576)
Added new source to star names and added new additional name to kappa Scorpii
Added tool to detect Intel C/C++ compiler in our Logger
Added new method into ConstellationMgr class - getConstellationsEnglishNames() to get English names of all constellations in the selected sky culture [Scripting Engine]
Added new one script ‘Constellations Tour’ to organize the tour around constellations of the loaded sky culture [Scripting Engine]
Added constellation boundaries for Chinese Skyculture (GH: #584)
Added more values to correctly detect MSVC version
Added few scriptable methods into HighlightMgr class to manage highlight points
Added translation support for strings within scripts
Added Chinese medieval sky culture (GH: #604)
Added Alipurduar town (West Bengal; India) to the default locations list (GH: #606)
Added extra check-point for data directory in the StelFileMgr class
Added DSO textures
Added sensor crop overlay to Ocular plugin (GH: #612)
Added tool for allow filetype selection for Screenshots (GH: #623)
Added core.getPlatformName() and core.isMediaPlaybackSupported() methods into scripting engine
Added scripting function isModuleLoaded()
Added graph “Transit altitude vs Time” into AstroCalc/Graphs tool
Added small simplification to scripting through adding master switch by types for grids, lines and points on the sky [Scripting Engine]
Added showing labels for named highlights (GH: #638)
Added allow setting location of User Data Dir via environment variable.
Added scripting graphics tool [Scripting Engine] (GH: #640)
Added LMC and SMC as addition names for Magellanic Clouds
Added classifications support for sky cultures
Added support 2 southern deep sky catalogues (NGC subset; esp. for southern observers)
Added armintxe, paleolithic sky culture and landscape (GH: #628)
Added demo script for martian analemma [Scripting Engine]
Added support sols for setDate() method [Scripting Engine]
Added code, who indicate to hybrid graphics systems to prefer the discrete part by default (GH: #649)
Added support for constellation boundaries thickness (GH: #653)
Added Maya constellations (GH: #635)
Added 2 Babylonian skycultures (GH: #647)
Added display of used (terrestrial) timezone for observation from extraterrestrial locations
Added special case for Satellites plugin: use texture for draw the crossing of the ISS of the Moon or the Sun
Added nightly illumination plus basic description for armintxe landscape
Fixed Ependes Observatory location (GH: #581)
Fixed scaling the distance in AstroCalc
Fixed naming the stars in AstroCalc tool when non-western skyculture is enabled (GH: #577)
Fixed sorting of column Distance in Astronomical Calculations’ Ephemeris tab (GH: #579)
Fixed wrong calculation the FOV of CCD in Oculars plugin
Fixed compile Stellarium without media features
Fixed behaviour of script (The old script ‘Constellations Tour’ was renamed to the ‘Western Constellations Tour’ and updated) [Scripting Engine]
Fixed documents for core.clear() method [Scripting Engine]
Fixed unit tests failure on Windows and some linuxes (GH: #586, #587, #588)
Fixed the user interface problems for lenses in Oculars plug-in (GH: #580)
Fixed copyright years in CREDITS.md file
Fixed checker in the StelFileMgr class (GH: #589)
Fixed macOS User Data Directory in documentation (GH: #593)
Fixed bug report address for .desktop translations
Fixed a typo in Scenery3D plugin (GH: #600)
Fixed selecting LMST, LTST and system_default timezone names
Fixed math error in StelHips (GH: #599)
Fixed a potential memory leak in libtess (GH: #598)
Fixed error for ephemeris calculations time window (GH: #605)
Fixed description data for textures.json
Fixed missed translatable strings in StelSkyCultureMgr class
Fixed CWE-404 issues
Fixed crash when script tried delete already deleted labels (GH: #625)
Fixed zooming behaviour
Fixed time zone issue in AstroCalc/WUT tool
Fixed DSO texture overlay issue (GH: #655)
Fixed FTBFS issue on some linux systems
Fixed bad behaviour time zones in the location panel (GH: #602)
Fixed crash when selecting certain dates in 1 AD for some time zones on Windows (GH: #594)
Fixed default limits for graph “Transit altitude vs Time”
Fixed translation the “Armintxe Cave” string (GH: #657)
Fixed airmass calculation for deep-sky objects
Changed default constellations font size
Changed HiPS behaviour: don’t show tile if it is hidden by children
Changed behaviour of version checker: introduced the additional check for latest version
Changed behaviour of the BottomStelBar::updateText() method (GH: #596)
Updated Reingold and Dershowitz algorithm of DeltaT (New algorithm was taken from the Calendrical Calculations: The Ultimate Edition book)
Updated cmake rules for ICC/ICPC support (Intel C/C++ compilers)
Updated GUI in Oculars plugin
Updated Stellarium User Guide
Updated technical documentation
Updated Amalthea texture
Updated scripts (added i18n support)
Updated scripting API: added format specification for screenshots. (GH: #623)
Updated the code (thanks for PVS-Studio to the finding an issues)
Updated DSO textures
Updated textures of LMC (GH: #632)
Updated jquery and jquery-ui in Remote Control plugin (GH: #620, #621)
Updated scripting engine: MilkyWay saturation scriptable now
Updated scripting engine: expanding the core.clear() method
Updated Satellites plugin: harmonized function name, added a property [Scripting Engine].
Updated KoreanCM.isl file - typofixes (GH: #639)
Updated RemoteSync plugin: suppress unsuitable properties (GH: #642)
Updated AstroCalc/WUT tool: optimizations
Updated AstroCalc/Positions tool: optimizations
Updated AstroCalc/Phenomena tool: optimizations
Updated contact info for plugins
Updated Sterngarten model description
Updated behaviour of the options on Starlore tab
Updated list of extraterrestrial locations
Updated time zones behaviour: make custom time zone use a full property of StelCore
Updated time zones behaviour: preserve custom timezone setting
Updated LocationDialog behaviour: Return to default location resets location list.
Removed a long time abandoned incomplete LogBook plugin
Remove old deprecated methods in scripting engine
Remove languages without translators and with translations lesser than 1%
Buongiorno, sto cercando di tracciare su stellarium il percorso della cometa C/2029 Y4, perchè il programma di da solo un punto, senza peraltro evidenziarlo con il simbolo della cometa. Qualcuno ha esperienza su questo ed è a conoscenza delle modalità per tracciare il percorso in cielo della cometa ed anche, eventualmente, la geometria della coda?
