Discussione: TAL Klevtsov/Cassegrain
04-07-2020, 03:27 #1
Da molti anni tengo d'occhio questa configurazione, in teoria dovrebbe essere superiore ai mac/cas, qualcuno ne è in possesso ?
In rete o trovato solo la focale 8.5, molti anni fa so che la TAL russa lo produceva a f10, ma la TAL americana e la russa svenduta ?
Le somiglianze degli strumenti ed accessori è evidente, son proprio rimasto indietro.
Technical Specifications:
Aperture diameter, mm 250
Focal length, mm 2130
Aperture ratio 1:8.5
Resolution limit 0.5"
Magnification 85X,170X,213X,426X
Limiting stellar magnitude 14m
Optical Scheme Klevtsov /Cassegrain
Finder, visual magnification, x
objective lens diameter, mm 9X50, Illuminated
Focusing device 2", 1.25",Crayford
Tube length, mm 660
OTA Material Aluminum Alloy
Telescope weight, lbs 33
TAL-250K 8.5 is the latest model of the Klevtsov/Cassegrain designed telescope. Primary mirror correction is made without removing the focusing mechanism during a simple star test. Portable design with a superior Klevtsov optical scheme and durable construction allows you to take this powerful telescope with you on the road, easily and worry-free. Klevtsov's revolutionary catadioptric design employs a sub-aperture meniscus correcting lens (like the familiar Maksutov) combined with a Mangin mirror-lens secondary. Diffraction artifacts are well controlled by unique curved spider vanes. OTA is made from an aluminum alloy.
04-07-2020, 07:45 #2
Re: TAL Klevtsov/Cassegrain
I klevstov cassegrain sono strumenti interessanti ma hanno avuto poco successo.
Spiegami cosa ti fa pensare che siano superiori ad altri cassegrain modificati però, e in quale ambito applicativo.
Paolo
04-07-2020, 08:15 #3
Ho "pescato" una vecchia, ma illuminante discussione:
https://www.astronomia.com/forum/sho...grain-TAL-200KNewton: GSO 303/1500; 150/1400; Bresser NT-150L Hexafoc - Mak: Sw 127/1540 BD; VMC11OL - rifrattori: 50/600; 70/350; ETX70 AT; 70/700; 77/910; 90/500.
04-07-2020, 10:18 #4
Ciao cherubino, chiedo per informarmi essendo stato molti anni lontano da questo mondo, possiedo due vecchi newton TAL1 e TAL2 la cui qualità ottica degli specchi e molto buona, vista anche la tua recensione e quella di altri molto positive. Partendo da questo presupposto il Klevstov ha superfici sferiche di facile lavorazione, la vecchia TAL lavorava benissimo gli specchi e ho fatto uno più uno senza informarmi più di tanto.
Stò orientandomi alla ricerca dello strumento definitivo per uso visuale planetario e a breve anche fotografico, per alta definizione, no rifrattori,trasportabile l'età avanza ed ho un ottimo sito a pochi chilometri, un buon mak/cas a f10 potrebbe essere la soluzione ?
Complimenti per il sito e le recensioni.
04-07-2020, 10:22 #5
Confronto tra Maksutov-Cassegrain 127 e Schmidt-Cassegrain 127
Di over885 nel forum Telescopi e MontatureRisposte: 44Ultimo Messaggio: 26-06-2021, 18:36 -
Schema Klevtsov–Cassegrain TAL-200K
Di manumilian nel forum Telescopi e MontatureRisposte: 8Ultimo Messaggio: 27-09-2016, 17:09 -
smith cassegrain
Di gasparino nel forum Telescopi e MontatureRisposte: 26Ultimo Messaggio: 05-11-2015, 11:47 -
Maksutov Cassegrain
Di etruscastro nel forum Telescopi e MontatureRisposte: 4Ultimo Messaggio: 28-09-2014, 18:27 -
Schmidt Cassegrain
Di etruscastro nel forum Telescopi e MontatureRisposte: 6Ultimo Messaggio: 22-05-2012, 15:38
Ieri, 15:57 in Binocoli
