Discussione: Stellarium 0.13.3
26-04-2015, 09:01 #1
- Nov 2013
- Montecastrilli (TR)
- 701 Post(s)
Stellarium 0.13.3
Disponibile al download l'ultimo aggiornamento, Stellarium 0.13.3
26-04-2015, 09:28 #2
- Jan 2013
- 154 Post(s)
Re: Stellarium 0.13.3
Scaricato ed installato, funziona a dovere come sempre
Grazie per la segnalazione.
Ecco la lista completa dei cambiamenti e migliorie apportate:
- Added Scenery3D plugin: enable support 3D landscapes
- Added ArchaeoLines plugin: a tool for archaeo-/ethnoastronomical alignment studies
- Added new DSO catalogs: Barnard (B), Van den Bergh (VdB), Sharpless (Sh 2), H-α emission regions in the Southern Milky Way (RCW), Lynds' Catalogue of Bright Nebulae (LBN), Lynds' Catalogue of Dark Nebulae (LDN), Collinder (Cr) and Melotte (Mel)
- Added tiny visual improvements for info about comets and minor planets
- Added Hungarian translation for Aztec skyculture
- Added Russian translation for Western: H.A. Rey skyculture
- Added support of meteors for Windows/MSVC packages
- Added patch for multiscreen setups
- Added tui/tui_font_color option for change color of text user interface (LP: #1421998)
- Added new version of GCVS
- Added implementation of polinomial approximation of time period 1620-2013 for DeltaT by M. Khalid, Mariam Sultana and Faheem Zaidi (2014); http://dx.doi.org/10.1155/2014/480964
- Added new line on the celestial sphere - opposition/conjunction longitude (LP: #1377606)
- Added texture for Ceres (LP: #1271380)
- Extended list of proper names for deep-sky objects
- Fixed position of Great Red Spot (LP: #490019)
- Fixed bug in planet shadow shasder (LP: #1405353)
- Fixed flickering Moon problem (LP: #1411958)
- Fixed jittering moons (LP: #1416824)
- Fixed visibility objects on distance over 50 AU. (LP: #1413381)
- Updated the Spherical projection to be HiDPI aware. (LP: #1385367)
- Restore unit testing for refraction and extinction. Fixed issue in unit test for DeltaT and fixed small issue for DeltaT.
- Fixed issue in core.setObserverLocation (to a new Planet travels always 1 second) (LP: #1414463)
- Fixed issue for cursor, who points to a wrong position after orbit update (LP: #1414824)
- Fixed ignore the Enter key for online search dialog within Solar System Editor plugin (LP: #1414814)
- Fixed package issue for Windows XP (LP: #1414233)
- Fixed crash when trying to select a satellite with invalid orbit (LP: #1307357)
- Check of updates has been removed (LP: #1414451)
- Fixed issues in Search Tool (LP: #1416830)
- Fixed code to update ConfigurationDialog size (LP: #995107)
- Behavior of JD/MJD has been refactored for Date and Time Dialog (LP: #1417619)
- Avoid delaying for the telescope control slew commands over TCP (LP: #1418375)
- Avoid crash when clicking 'Lookup locations on network' checkbox in Locations window (Debian: #779046)
- Updated bookmarks for Solar System editor plug-in (LP: #1425626)
- Allowing display the scope marker below the landscape (LP: #1426441)
- Allow fading of the landscapes without atmosphere (LP: #1420741)
- Allow change thickness of lines of the constellations (LP: #1028432)Blog Astronomia Pratica - IZ6GSM - Astrobin - Archivio RAW
26-04-2015, 09:34 #3
- Mar 2015
- Quartucciu (CA)
- 402 Post(s)
grazie phil,grazie giuseppe.
vi chiedo se avete disintstallato la vecchia versione o esiste un comando di aggiornamento.
26-04-2015, 09:35 #4
Non devi fare nulla, scarica ed installa fa tutto da solo.
-MAURIZIO-
26-04-2015, 09:59 #5
I nuovi cataloghi hanno incasinato le schermate, specialmente quello riguardante le nebulose oscure è veramente invasivo, in piena estate è un gran casino visto che la via lattea è stracolma di questi oggetti diventa un tappeto di quadratini (il simbolo che segnala la nebulosa) e si perde completamente tutto il resto.
Devo trovare il modo di disabilitare questo catalogo.-MAURIZIO-
26-04-2015, 10:35 #6
- Mar 2015
- Quartucciu (CA)
- 402 Post(s)
in uno dei vostri report, mi aveva suscitato curiosità la Galassia Balena. Non riuscii a trovarla (la rappresentazione) nella vecchia versione e nemmeno in quest' ultima
26-04-2015, 10:39 #7
- Jan 2013
- 154 Post(s)
Devi cercarlo con il nome in inglese 'whale galaxy', oppure con il suo indice di catalogo NGC 4631
26-04-2015, 10:43 #8
- Mar 2015
- Quartucciu (CA)
- 402 Post(s)
si si Giuseppe, oggetto Ngc. Ma mi individua la posizione senza rappresentarmi la foto dell'oggetto.
26-04-2015, 10:45 #9
- Jan 2013
- 154 Post(s)
26-04-2015, 18:01 #10
oia oia a me non regola più la magnitudine in maniera decente, ho un sacco di stelle nel cielo che sembra di essere nel deserto del gobi...è più spettacolare ma non è realistico per il mio sito, non mi da una via di mezzo, o niente stelle o il campo esteso dell'hubble!
Osservo con: MC 127/1500 su EQ AVX GoTo
Problemi con Stellarium 0.12.1
Di orione2000 nel forum Software GeneraleRisposte: 4Ultimo Messaggio: 19-05-2013, 21:24 -
stellarium
Di garmau nel forum Software GeneraleRisposte: 43Ultimo Messaggio: 11-05-2013, 19:39 -
Stellarium 0.12.1,il confronto
Di orione2000 nel forum Software GeneraleRisposte: 2Ultimo Messaggio: 23-04-2013, 08:01 -
Rilasciato STELLARIUM 0.12.1
Di marcom73 nel forum Software GeneraleRisposte: 5Ultimo Messaggio: 22-04-2013, 11:39 -
stellarium
Di marco nel forum Software GeneraleRisposte: 65Ultimo Messaggio: 18-06-2012, 18:09
PHD - Prima configurazione
