27-02-2013, 07:52 #1
- Jan 2013
- 154 Post(s)
Cometa C/2013 A1 in probabile rotta di collisione con Marte - Ottobre 2014
Un interessante articolo apparso ieri su Universe Today riguardante questa nuova cometa scoperta
http://www.universetoday.com/100298/...rse-with-mars/
"There is an outside chance that a newly discovered comet might be on a collision course with Mars. Astronomers are still determining the trajectory of the comet, named C/2013 A1 (Siding Spring), but at the very least, it is going to come fairly close to the Red Planet in October of 2014. Even if it doesnt impact it will look pretty good from Earth, and spectacular from Mars, wrote Australian amateur astronomer Ian Musgrave, probably a magnitude -4 comet as seen from Marss surface.
The comet was discovered in the beginning of 2013 by comet-hunter Robert McNaught at the Siding Spring Observatory in New South Wales, Australia. According to a discussion on the IceInSpace amateur astronomy forum when the discovery was initially made, astronomers at the Catalina Sky Survey in Arizona looked back over their observations to find prerecovery images of the comet dating back to Dec. 8, 2012. These observations placed the orbital trajectory of comet C/2013 A1 right through Mars orbit on Oct. 19, 2014.
Read more: Is a Comet on a Collision Course with Mars?
However, now after 74 days of observations, comet specialist Leonid Elenin notes that current calculations put the closest approach of the comet at a distance of 109,200 km, or 0.00073 AU from Mars in October 2014. That close pass has many wondering if any of the Mars orbiters might be able to acquire high-resolution images of the comet as is passes by.
But as Ian ONeill from Discovery Space points out, since the comet has only been observed for 74 days (so far), so its difficult for astronomers to forecast the comets precise location in 20 months time. Comet C/2013 A1 may fly past at a very safe distance of 0.008 AU (650,000 miles), Ian wrote, but to the other extreme, its orbital pass could put Mars directly in its path. At time of Mars close approach (or impact), the comet will be barreling along at a breakneck speed of 35 miles per second (126,000 miles per hour).
Elenin said that since C/2013 A1 is a hyperbolic comet and moves in a retrograde orbit, its velocity with respect to the planet will be very high, approximately 56 km/s. With the current estimate of the absolute magnitude of the nucleus M2 = 10.3, which might indicate the diameter up to 50 km, the energy of impact might reach the equivalent of staggering 2×10¹º megatons!
An impact of this magnitude would leave a crater 500 km across and 2 km deep, Elenin said.
While the massive Comet ShoemakerLevy 9 (15 km in diameter) that crashed into Jupiter in 1994 was spectacular as seen from Earth orbit by the Hubble Space Telescope, an event like C/2013 A1 slamming into Mars would be off the charts.
Astronomers are certainly keeping an eye on this comet, and they will refine their measurements as more data comes in. You can see the orbital parameters available so far at JPLs Solar System Dynamics website."Blog Astronomia Pratica - IZ6GSM - Astrobin - Archivio RAW
27-02-2013, 12:03 #2
- Feb 2012
- Varese provincia
- 560 Post(s)
Re: Cometa C/2013 A1 in probabile rotta di collisione con Marte - Ottobre 2014
Interessante. E' ancora presto, però, per dire che l'impatto ci sarà davvero.... Anche se sarebbe un grande spettacolo, e un monito per noi che non facciamo nulla....
27-02-2013, 12:22 #3
Un argomento per pochi. ....:(
inviato da Maurizio con Tapatalk-MAURIZIO-
27-02-2013, 13:24 #4
- Jan 2013
- Marina di Cerveteri (RM)
- 5 Post(s)
Che fine farà curiosity se ci dovesse essere l'impatto ?
Gianluca PaoneIl database delle mie osservazioni: Stazione Osservativa Marina di Cerveteri
27-02-2013, 14:05 #5
curiosity kill the cat ....
27-02-2013, 20:09 #6
- Jan 2013
- 154 Post(s)
Si, è vero, ma sarebbe davvero utile per iniziare a dirigere più seriamente (di quanto non si stia già facendo ora) l'attenzione verso queste possibilità. Considerando che di 'la fuori, oltre Plutone, MakeMake e Sedna, conosciamo praticamente nulla ^.-
Scusa, non ho avuto il tempo di tradurlo fino ad oggi pomeriggio, in questo articolo offro una semplice illustrazione di quello scritto in inglese
Dipende da dove sarà l'impatto, comunque direi, a occhio, che il minimo sarà una bella ed enorme tempesta di sabbia globale (che già si verificano senza 'l'aiuto' di queste cose a livello di intero emisfero). Poi in relazione alla distanza di impatto dalla posizione dei rover...be', il peggio è che vengano danneggiati da eventuali frane, o per la troppa polvere almeno Oppy non riesca a superare l'inverno marziano. Diciamo che gli scenari sono tanti...Blog Astronomia Pratica - IZ6GSM - Astrobin - Archivio RAW
27-02-2013, 21:10 #7
- Feb 2013
- Albuzzano (PV)
- 111 Post(s)
A vostro parere potrebbe essere un evento osservabile?
28-02-2013, 12:37 #8
- Jan 2013
- 154 Post(s)
Strano, avevo risposto ieri sera, ma il messaggio non c'è Comunque ecco qui.
Da Marte sarà uno spettacolo a quanto pare, sempre secondo i dati attuali, con la magnitudine che andrà da un minimo di -4 ad un massimo di -8 nelle previsioni! Dalla Terra comunque un oggetto così grande sarà sicuramente osservabile.
Per quanto riguarda l'impatto noi saremo un po' svantaggiati visto il periodo, dato che dall'Italia Marte si vedrà per qualcosa in più di un'ora dopo il tramonto del Sole, fino al tramonto del pianeta. Ma abbiamo vari orbiter lì sopra e tantissimi telescopi amatoriali e non qui sulla Terra. Sicuramente qualche immagini l'avremo!
Girando un po' sui forum generali, ho letto che è stato calcolato che un impatto con la luna più piccola del pianeta, Phobos, la disintegrerebbe senza troppi problemi. Qui invece ho trovato un animazione dal simulatore JPL della NASA con i dati attuali
28-02-2013, 14:18 #9
- Jan 2012
- San Damiano d'Asti
- 1 Post(s)
27-03-2013, 22:32 #10
- Jan 2013
- 154 Post(s)
Mi sa che Lampedusa la vedo male in questo caso, con tutti gli alieni che tengono le immagini di fronte ai rover saranno nei guai!
Effettivamente ora, in un nuovo articolo, le dimensioni sono state ridefinite da 1 a 3 Km di diametro, e la probabilità di impatto a 1 su 2000. Molto probabile un flyby prossimo al pianeta, che una vera e propria collisione.
Avremo anche la sonda MAVEN che dovrebbe raggiungere Marte poco prima del passaggio della cometa, anche se non sarà completamente operativa in quel momento specifico.
Trovate altro in questo articolo: http://science.nasa.gov/science-news...mar_marscomet/Blog Astronomia Pratica - IZ6GSM - Astrobin - Archivio RAW
Panstarrs, Lemmon e Ison, tre comete in rotta verso il Sole
Di denis nel forum Sistema SolareRisposte: 29Ultimo Messaggio: 20-03-2013, 12:48 -
Il cielo nel mese di Ottobre 2012
Di Stefano Simoni nel forum ArticoliRisposte: 3Ultimo Messaggio: 23-10-2012, 14:43 -
Report del 19 ottobre 2012
Di Bellatrix nel forum Report osservativiRisposte: 11Ultimo Messaggio: 21-10-2012, 12:21 -
Collisione nella Grande Nube di Magellano
Di Vincenzo Zappalà nel forum NewsRisposte: 13Ultimo Messaggio: 05-09-2012, 20:21
Ieri, 18:50 in Report osservativi
